[FOR SALE] 1966 Dodge Dart Station Wagon $6K
Mopar Automobiles For Sale
Thread Status:
  1. raywayne
    raywayne Member
    13
    6
    Jul 9, 2006
    Local Time:
    1:07 AM
    Contact Seller
    1975 360 V8 (unleaded heads), 1967-69 ‘Cuda 340 exhaust manifolds w/ annealed copper gaskets and ARP Bolts, RV cam, Centerforce diaphragm clutch, heim-joint clutch linkage, Edelbrock 500 cfm (electronic choke) Performer carb w/ Edelbrock Performer intake manifold w/ heat spacer between carb & manifold, solid state ignition, K & N air filter, ARC heavy duty battery, mini high-torque starter, A833 OD transmission, 8.75 3.23 open differential from 1968 Coronet, 1970 Dart air-condition radiator w/ shroud, 1974 Dart front disc brakes, late model Mopar aluminum dual brake master cylinder with heat shield between exhaust manifold and master cylinder, rare 6.5 X 15” on 4.5 big bolt pattern Mopar rallye wheels with 225-60-15 tires, front 1 -1/8th inch and rear 1” Addco sway bars, sub-frame connectors, KYB gas shocks, 7 leaf rear springs, Hurst roll-control with T-Handle w/ built-in metal release button, factory tranny hump for Hurst shifter, bucket seats, very good redone dark blue dash pad, redone light blue vinyl back seat, 4 - lap seat belts, Mopar rallye steering wheel w/ new turn signal switch, turn signal/parking lights wired to be on with Halogen headlights, 3” Auto-Meter tachometer, AM-FM radio with interior antenna, working heater and defroster, all gauges work, dual outside mirrors, day/night interior mirror, correct Stant locking gas cap, all doors & tailgate work and lock with good door interior panels.
    INCLUDES: new dark blue carpet - stretched for tranny hump in box, second very good windshield (current one is doing the typical Mopar separation, de-laminating), ‘70s blue leather Cordoba bucket seats with center arm-rests (not installed), tailgate torsion bar (not installed), all interior & exterior trim - including very rare hood piece, 4 extra doors with glass.
    NEEDS: body work, floor repair, headliner, small exhaust leak–driver’s side, sticky speedo ( it works, just needs a tap on the face-needle needs to be bent ever so slightly), rear driver’s side armrest missing (pad is there), horn won’t honk even with a new turn signal switch and horn relay, even traced the continuity???
    * I’ve been restoring this car since 1989, but I lost my garage space, and I’m getting too old to work on it and it has had to sit outside for the last couple of years. It was my daily driver until now, but needs to go to someone who can finish it, appreciate it, and enjoy it. It’s a cruiser, not a dragster, and is currently registered.
    • Like Like x 5
    • Treblig
      Treblig Well-Known Member
      5,867
      3092
      Oct 5, 2013
      South Texas
      Local Time:
      3:07 AM
      Many, many FABO members are always asking if the late 60s 340 manifolds will fit in the early As. You seem to have used these manifolds. Even though this is a "for sale" ad I would like to ask if it was very difficult to fit the 360 in the engine bay with the 340 manifolds?? Power steering?? Did you have to modify the body or the steering (on either side), especially on the driver's side to fit these manifolds?? Pics of the driver's side. Looks like a nice build!! My apologies to the moderators but this is a subject of great importance to many early A owners (not me).....these are questions about the car after all.
      • Like Like x 3
      • Agree Agree x 2
      • Syleng1
        Syleng1 Karma is real and Life is short... FABO Gold Member
        1,352
        929
        Jul 5, 2005
        North Franklin, CT
        Local Time:
        4:07 AM
        Where is the car located?
        I checked your profile and your location did not come up.
      • 69FBCuda
        69FBCuda Life in the Fast Lane
        2,076
        1108
        Aug 28, 2014
        Florida
        Local Time:
        4:07 AM
        California tags
      • JDMopar
        JDMopar Well-Known Member
        2,544
        1350
        Jan 19, 2012
        Candler, NC/Myrtle Beach, SC
        Local Time:
        4:07 AM
        It's in or near San Francisco....listed on Craigslist there. Worth every penny the man is asking!
        • Agree Agree x 3
        • Valiant63
          Valiant63 Early A-body Valiants
          1,382
          327
          Dec 29, 2007
          eastern, PA and central Florida
          Local Time:
          3:07 AM
          I want it, but getting it to Florida would be a pia.
        Thread Status:
