[Found!] 1966 or 66/67 273 4 barrel intake manifold
  • Thread starter Thread starter Deleted member 38666
  • Start date Start date
D
Guest
Members. I am in need of a 1966, 273, 4 bbl intake manifold part number 2536636 or a 1966/1967, 273, 4bbl intake manifold part number 2536536. I believe these part numbers are correct, but I am not for sure. I got these part numbers off of our forum. Toolmanmike has added input regarding the correct numbers in this thread. Let me know if you can help me with this. What would be the best carb to use on a 66 273 4bbl where the block has been bored 0.030 over? Heads have been redone to HiPo specs, using a Racer Brown cam which is a little stiffer than the 66 OEM 273 HiPo. Thank you. Old Dart 66
2536563 is 1966 and 67 federal emissions and 2536771 is with CAP for both years.
