[WANTED] 1966 Plymouth Valiant front door arm rests
trudysduster
Corinth, Ky.
I am looking for both front door arm rests for a 66 Valiant. Hoping to get the same color as what I have if possible. They look like a 2 tone green as pictured. shipping to zip 41010. Thanks,Bill
Are you looking for just the pads or plastic bases too? Keep in mind Barracuda is different, they are longer than Valiant ones.
well from what I have found the pads screw to the bases right. I found the bases new and there is nothing wrong with the pads so I guess I need the bases and then paint them car color. I dont know. I never had a 66 Valiant. I just got it home and both bases are broken. do you have 2 bases
I do not, but the bases are easy to find, think most new ones are chrome but that would look nice unless you still wanted to paint them. The originals are fragile, not sure how strong the new ones are. And yes, the pads screw to them. My 66 Valiant 100 has the short bases, they are the same length as the rear ones in the Barracuda...Barracuda had 2 sizes. On your car...are the front the same size as the rear?
have not checked yet
Either measure the old bases or the imprint of the base on the door panel to get the correct ones. Usually, the 4 doors use the shorter bases on the front and rear. The 2dr's use the longer ones on the front, but, it might also depend on the trim line of the car. Signets and Barracudas came with chromed plastic bases. Most of the other models came with colored plastic bases. The ash tray versions go in the rear....solid ones up front.
My 66 100 2-door sedan has no rears and short ones up front
The two shorter black pads with ash trays are sold. They measured 9" on the pad. I still have the bases. Message me if interested.
ok, thanks for the info
I measured them today and it looks like the fronts are 9 1/2 " and the back s are 10". I dont know if that is supposed to be right. I think I saw somewhere that they should be 9 & 11"
I just measured these and the front and back are the same size. It looks like the same bases. the pads are 9". Only difference is the ash tray in the back. The distance from the front screw that holds them on to the window crank is 2". I dont know how you could put any bigger ones on here. Overall length is 10". which ones do you have that fits these measurements.
I can get 4 chrome bases from Classic industries. do you have 2 front pads that are 9" long for the 10" bases that are in good condition. I can stain them the color I want. And if you have 2 of the 10" bases that is plastic for the front , I can paint them but if not I can get all 4 bases chromed from Classic.
Hey @cosgig do you have any bases or pads for a Valiant?
yep, I have a complete set, black. As is standard with the Valiant, both front and back use the 9” bases and pads, which is what I have. I have the other 2 black bases not pictured here, but the silver ones in the pic were better so I put them with the group.
what are you asking for the set. How much for a base for pass. side front
what are you asking for this complete set of arm rests. I have not heard back from you on the pass. side front you said you have so I may have to buy the whole set. let me know.
