On my '66 Valiant, the fuel and temp gauges don't quite go all the way to where they should be. By wiggling wires (main cluster feed, and bulk head connections, I've had the guages go all the way, proper, and now showing low.
The wiring on this car hasn't been hacked, is pretty cherry.
I reached behind the dash and wiggled the voltage regulator, then pulled the ash tray so I could see back there, pulled the regulator, and noticed a condenser bolted to the back of the cluster and the wire wasn't connected to anything. It has a spade connector on the end and looks factory. Almost looks like it could be plugged in with the regulator.
Other than that everything works fine. Anybody have any ideas or pictures? I've looked and couldn't find anything, and schematics give me a headache.
Thanks,
Russ.
Thanks,
Russ.
