[SOLD] 1967 273 timing tab
physixx
Edison, NJ
Hi all. I'm looking for the timing tab for a 1967 273 engine. I have the front cover and balancer but can't seem to find the tab. Anyone have one that they want to part with?
Thanks.
Ken
Edison, NJ
Is it the type that uses the two lower water pump bolts? Same as the early ones?
Just so you all know, there are 2 different bolt on timing tabs for the early timing covers! There is a long and a short style, not sure of each application or whether they are marked the same, but I'll dig up one of each and A/B them!
I found one. Thanks 65 Dartman.
Cosgig - I know about the two different tabs and each has a different timing mark position. If need be, I can remark the balancer or the tab from 65 Dartman. Thanks for the input though. I appreciate it. :-)
Ken
