fbcuda69
I have a left over Plymouth Barracuda passenger door that will fit 1969, 1968, or 1969's. Please note the inside of the door does have the lower vent slot that I believe was found on 67' and 68's but not on 69.
I sold my car so selling off last of remaining parts. Door is overall structurally very sold for the most part; couple areas that would need attention are bottom corner(s) see pics and on top panel on inside where there was small ding that someone hammered out, but left little dimples from stretching metal I presume. There are no dents, dings, etc. to speak of on the outside of the door. The metal is very solid on most of the door except in lower corner(s) and some pitting on the bottom in areas as shown. This is definitely a very restorable door that in the right hands and with a little effort could be made into a nice door for their car. The vent window/chrome area is pitted/peppered and would advise changing it out with a better replacement. Priced low so hopefully someone will save it otherwise it will be going to the scrap heap with some other metal I have and I will get some dollars from that. Local pick up only. $30 Thanks
