This timing cover is correct for small blocks 1967 thou it will work for earlier models also. This cover has the timing marks on a separate timing tab that bolts to the lower two water pump bolts on the passenger side. I cleaned and media blasted the cover inspect it for damage. Chase all the threads with a tap. Any hole that is not up to par I install a Heli-Coil insert. Includes the lower two water pump bolts. And is paint Chrysler Red. This is a hard to find timing cover. Mopar part number is 2128896 and is date coded 1967. $70.00 FREE shipping included in the USA.
