1967 Backseat
McCuda67
New Member
Heber, Utah
Does anyone out there know if there is a difference in the coupe fast back and convertible rear seat? It appears to me that the convertible and the coupe are the same and the fastback or formula S is a fold down. Any help on this would be greatly appreciated.
Since you noted Fastback and Formula S I'm assuming you are referring to 67-69 Barracuda?
I am 99% sure that the convert seat is unique to coverts and I believe that 67-69 Dart and Barracuda converts use the same seat frames as the side armrest plastics is interchangeable as long as you can stand the slightly different trim line on the sides.
