[SOLD] 1967 BARRACUDA 4 speed power steering column (mint)
cuda67man
upstate
Rating - 97.2%
35   1   0
have a 4 speed power steering column (factory black) that ive had in a box for several years for a project that never happened. It was at that time pulled from a driving car and worked perfectly. the bearings seem perfect with no wobble. it was bead blasted and repainted as was pulled with the shaft in satin and the cup part in matte. the blinker mechanism works great and the blinker rods chrome looks perfect. it comes with I think everything needed to reinstall. it comes with the inner and outer brackets with the foam gasket and the wire harness intact with very pliable plastic mount. even has the ground wire and oval factory plastic dust cover. I believe it can be used as auto with console as well as other years. very nice column. $250 plus ship
You might point out the power steering shaft length. I think the aftermarket adapter to manual steering would require the power steering box coupling also. GLWS
