1967 Barracuda Notch
roughidle
Super Platinum Member
Pennsylvania
Well, I figured I'd start posting pictures of my big steel mess of swiss cheese I'm starting with. I got this car shortly after becoming a member here last year and have been collecting a lot of information and parts since then. Thanks to all of you that have helped me in one way or another.
This car will finish in the following condition:
- 400 BB Stroked to ~470 - Motor Plates mounted
- 727 Trans Reverse manual VB
- 8-3/4" Rear 4.??
- Spring Relocation w/ s/s springs
- BBP '73+ front Disks and suspension
- BBP Mosers
- 12 Gal Fuel cell
Plus all the trimmings.....
Here is what I am starting with :banghead::banghead::banghead::banghead::banghead::banghead: :protest::protest::
I love how someone could "patch" a frame with 26 gauge galvanneal, "try" to flux core weld it (splatter welding is back in style), and then bondo and undercoat over it....
There was three layers of rear quarter on this car that had been BRAZED in over the past 40 or so years....
I want to do this :finga: to the car, but I just can't. I feel the need to test everything I know and believe I can do to resurrect this car instead of just kicking it to the curb.
Don't expect daily or weekly updates on this car, but I will try and keep this updated at least on a monthly basis.
This is going to be a long tough ride for sure....
What I could use some help on right now is the last set of pictures of the rocker patch. What I'm running into is the rearmost brace is about 7/8" too far inboard when I lay the rocker patch in whereas the front brace and backing plate is nice and flush.... Is this what I should expect when trying to use a patch panel, or is there something wrong that I'm not seeing...
How was that brace aligned before you cut the old inner rocker out? Could it be that your substructure is so weak that when you cut it away it "sprung" to an unloaded position where it was happier? Body tweaked from ditch runnin'? I'm thinking that there are some serious body alignment issues for that much gap between the mount and the inner rocker.
I admire your fortitude to wanting to tackle that beast! L8r
There wasn't much left of the "structure" of the rocker and inner rocker there when I started cutting to good metal. It certainly didn't spring when I cut away what was left. The doors did close on it pretty well with no large gaps anywhere when I brought it home. I can't really see how this thing is tweaked because the top of the rocker panel (the door sill and ribs that the door would seat in against seem to be nice and straight. I can't find any visual areas of an impact damage on either side of the car...just a lot of rust...
Wow. That's alot of rust, but I sure am glad someone is saving that thing! Love the notch-backs. Will be watching.
EDIT: Can we get some overall pictures?
Not much to look @ right now, I have it all disassembled....
I will try and keep posting as I progress through therapy....
