1967 Dart GT Accelerator Pedal Assembly: I’m a Newbie So Don’t Laugh…
OG67DartGTC
Arizona
I have a 1967 Dodge Dart GT Convertible and I’m having an issue finding out what this part is on the accelerator pedal assembly and where I can get one! I’ve been searching on interweb with no luck…please take a look the attached pics and let me know what this is and how I can search to find this part! Thank you all in advance…
It's an anti rattle
I'm not sure if they are reproduced.
Start a wanted ad, the assy is the same on A bodies 67-70 ( probably thru 76) as far as I know
It's a spring to keep the pedal pointed on the right angle. And a bit of anti rattle.
Thank you sir…I looked it up in the 67 Parts manual and all it says is “Clip 14-01-8”…I appreciate your quick response!
You could probably make one from spring wire.
I mistook the clip that holds the pin into the gas pedal for the spring. The clip 14-01-08 is only an anti rattle
I have 2 , 1 has that clip & 1 doesn't..all I can see s it may be an anti rattle. As I see no other purpose for it.
The one with out seems to have witness marks that there was a clip there.
It's also not where I thought it was located.
I agree it's an anti rattle.
You don't want us to laugh?? Oh c'mon, where's the fun in that!? Sorry, I gots nutin except anti-rattle.
Yep, start a Parts Wanted Ad for a spring or a pedal assembly. Marketplace forums.
