1967 Dart Gt Build Card
I'm at work right now but can help you.
In a nut shell, each punch represents the number to the far right for the column it is in.
The first 8 punches are 32704016 aka the shipping order number.
First digit is scheduled production month (3)
Next 2 are day (27)
Next 5 are seq number (04016)
On your trunk rail you should find
7232704016 stamped in.
7 is year
2 is Hamtramic plant
The reast is as above.
By the way your convert is the only other DD1 Car I have ever seen
Mine is also a 67 GT Convertible built about a month and a half before yours.
Search FABO for IBM card and my handle there is a tone of info.
The punches in the top 2/3 rows indicate a letter of the alphabet based on the number below it.
Column 29 30 31
Has the top most hole punched and then the punch below it is a 4 D is the 4th letter in the alphabet.
Google " IBM punch card decoding"
Look for the gen5.info result and click on the link
Another example of letters...
Trim
P4B
P is punch in 2nd from top row and a 7 below it.
4 is 4
B is top row punch with a 2 below it
