[WANTED] 1967 Dart Reverse Light Housings
scautoworks
New Member
Santa Cruz, CA
Hello!
I am a classic car shop that has been doing a lot of work to a customers 1967 Dart. It came in needing a bunch of assorted work such as a B&M shift cable that melted against the headers, it had been sitting for years. It had two toggle switches that were for torque converter lock up and overdrive on an A500. It also had a neutral safety switch with no reverse light output. The wires from the switches were cut off at the connector housing by rodents, they were quick disconnect terminals glued in. I had to lower the valve body to access and clean out the connector housing. It is now set up with automatic overdrive. Anyway, the bumper is missing the reverse light housings, I have it all wired up. Does anyone have a pair for sale? I cannot find them anywhere. Apparently the owner has been driving the car since its restoration 20 years ago without reverse lights in the bumper.
Thanks so much!
For what ever it's worth this is what they look like. Missing lense. Broken bulb is in the bulb holder socket.
Overall 4.5" x 2.65"
Part number on the housing is 2575872 they fit Right or Left
2585040 from parts book.
