1967 (one year only) Radio Delete Plate for BARRACUDA
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I all, I helping a member with a radio delete plate for his Barracuda, I have deduced the height and width and the post spacing and length but what I can't deduce is the thickness.
If anyone has an OEM 67 Barracuda radio delete plate handy would you PM me so I can get the dimensions I need to finish this project.
It looks to have part number 2822554 on the back
I have seen the several posts here on FABO about the delete plate but none that I found had anything available about the thickness.
Thanks all.
Dana
Thanks all.
Dana
Same as 71 rally Dash delete plate just different color. I believe I have one
It has a unique edge, mine in pic and I don't even recall if it goes around all 4 sides.
The recess on the back is on the top, on the bottom in the pic below.
It's there to clear the upper part of the radio dash bezel, which goes right up to the upper edge.
