[SOLD] 1967 Plymouth Barracuda Convertible - rust free
jeremylyniel
Virginia
Originally a 273 2bbl, 727 auto, console, 8 3/4 rear with sure gripe 3.23 gears. Now a 360 crate motor (300 hp). The motor was went through about 5 years ago and has less than than 4,000 miles put on it. It is also now a 4-speed (1968 transmission) with new Hurst shifter. It still has factory power steering, manual disk breaks (calipers have been gone through).
All sheet metal from the door back has been professionally replaced. Both quarter panels, both sides of the trunk extensions, trunk pan, rear valance, inner rear wheelhouse. All other rust was removed and replaced with metal. Nothing was covered up with bondo. Car has been garage kept. However, it does have a few rock chips from being driven.
New items:
Interior
  • Instrument cluster
  • Entire dash painted and color matched with steering column, dash pad
  • Dash pad
  • Steering column (completely rebuilt)
  • Glove box trim plate
  • Carpet
  • Door panels
  • Door handles
  • Arms rests (all)
  • Window cranks (all)
  • Windshield
  • Top with rear glass
  • Steering wheel
  • Custom drive shaft with new u joints
  • Tach
Champion 3 row radiator
15” wheels/tires (small bolt pattern)
Front wiring harness
Dual exhaust with factory style/sound mufflers
Tail lights
Front wiring harnesses
PST front end
Front and rear sway bars
New fuel tank & sending unit
Leaf springs
Brakes have been gone through
Non stock parts
Aluminum radiator
Steering wheel
Bluetooth unit installed under the dash (dash/radio has not been modified)
2 speakers in dash
2 speakers in kick panels
I have the receipts for 75% of the parts. I’m asking $24,000. The car is located in Roanoke, VA.
Front and rear pictures.
Here are some common questions I’ve been asked:
How long have you owned this car?
I bought the car at the 2010 Mopar Nationals
Did you have the body work done and changed to a 4-speed?
Yes, I paid a professional (the labor on body work isn’t cheap) to do the body work and to covert it to a 4-speed. It has the proper spot welds and seams. The 4-speed was installed with all the correct Mopar hardware.
Here are more pictures that have been requested. The last 2 pictures are the rock chips that I’m trying to show. This is a really nice car, but it’s not a show car so it gets driven.
