jeremylyniel
Originally a 273 2bbl, 727 auto, console, 8 3/4 rear with sure gripe 3.23 gears. Now a 360 crate motor (300 hp). The motor was went through about 5 years ago and has less than than 4,000 miles put on it. It is also now a 4-speed (1968 transmission) with new Hurst shifter. It still has factory power steering, manual disk breaks (calipers have been gone through).
All sheet metal from the door back has been professionally replaced. Both quarter panels, both sides of the trunk extensions, trunk pan, rear valance, inner rear wheelhouse. All other rust was removed and replaced with metal. Nothing was covered up with bondo. Car has been garage kept. However, it does have a few rock chips from being driven.
New items:
Interior
Champion 3 row radiator
15” wheels/tires (small bolt pattern)
Front wiring harness
Dual exhaust with factory style/sound mufflers
Tail lights
Front wiring harnesses
PST front end
Front and rear sway bars
New fuel tank & sending unit
Leaf springs
Brakes have been gone through
Non stock parts
Aluminum radiator
Steering wheel
Bluetooth unit installed under the dash (dash/radio has not been modified)
2 speakers in dash
2 speakers in kick panels
I have the receipts for 75% of the parts. I’m asking $24,000. The car is located in Roanoke, VA.
New items:
Interior
- Instrument cluster
- Entire dash painted and color matched with steering column, dash pad
- Dash pad
- Steering column (completely rebuilt)
- Glove box trim plate
- Carpet
- Door panels
- Door handles
- Arms rests (all)
- Window cranks (all)
- Windshield
- Top with rear glass
- Steering wheel
- Custom drive shaft with new u joints
- Tach
Tail lights
PST front end
Leaf springs
Non stock parts
Aluminum radiator
Steering wheel
2 speakers in dash
