Don't be confused with the Basic V-100, and the flashy 'Signet'.
The Signet had decor interior, rocker panel moldings, roof drip moldings,
'B-Pillar' vertical chrome molding, and side window moldings.
I believe the V-100 with the 273/235 HP weighed in at #2835 lbs.
One wonders, if Mopar had rated the 273/235 HP 'Commando' at a more true rating of 220 HP,
and offered up a true 273/235 HP called the 'HP Commando'.
* Bumpier solid lifter camshaft (.450 lift / 266* Duration)
* Higher-rate valve springs (240 lbs. Heavy-coil w/damper)
* Carter AFB (575 CFM), off of the 383/325 HP engine.
