[SOLD] 1967 Valiant Race/Pro Street roller
gtsuperbee
Active Member
Rating - 0%
0   0   0
1967 valiant. caged, mini-tubbed (about 15 1/2" from wheel tubs to wheel lip). This car has fiberglass bumpers, hood, and decklid. It has disc brakes up front with a line-lock. The rear is a mono-leaf (moved to the frame rail) with a floating ladder bar set-up. This car has a stock width b-body 8 3/4 rear end under it with an open gear. This is just a roller. What you see is what you get. This car does have a clear ohio title in my name and the VIN is riveted on the door jam(factory in 67), so you can plate, insure, and put it on the streets. The fuel system is complete to the regulator. It has centerline front wheels with very nice tires. The rear are Fentons with older slicks Asking $2,100.00 This would make a great entry level race car or inexpensive, fun street car. The side windows are just pinned plexiglass by the way. PM me here. Thx. The car is located in Boardman, Ohio 44512 zip. By the way, I believe the k-frame in the car is a 6 cylinder k-frame. I have to double check. Either way, I am almost 100% positive, that I still have an extra v8 67 a-body k-frame in my one garage. If so, you can have that too.
I am not sure if I can deliver it or not. I have been super busy trying to wrap up stuff before winter. I can see if any of my friends would want to deliver.
could you pm a contact number have a big block I would love to squeeze in that car ty steve:burnout:
Pm sent
The body isn't bad. Minor rust low. The car went down the track in september. It will need a motor/trans, shifter, and gear mainly. I figure whoever buys it is going to narrow a housing to take advantage of the tubs. It is cheap and cash talks. Even the fuel system is complete
If I get some time after work, and it is still daylight, I will get some undercarriage pictures. I don't know what it weighs. I could answer questions 10 times quicker with a phone call
I have a couple 69 coronet 440s for sale. a #s matching 383 4 door and a 69 318 2 door
I have way too many cars, and it is freaking the neighbors out. $3000.00 on the 4 door and I am not sure exactly on the 2 door. I was going to stick it on ebay and let it fly
A deposit has me all jacked up. I am bound for a little longer. Never again will I take someone's deposit, especially on something so cheap. It will be all or nothing.
