1967 Valliant Emergency Flasher Switch Wiring
Chuck Piepont
Austin, TX
Rewiring a 67 Valliant and want to know witch terminal on the emergency flasher switch is power in.
See photo. Ignore the red mark-.
There is no in or out, in the off position there are no connections, in the on position they are ALL connected.
You can remove the switch and your turn signals and brake lights will still work.
It doesn't care which way you plug it in.
What it does is connect the front left, the front right, the brake light and the flasher together.
So in the off position, no continuity between any of the terminals, in the on position continuity between all the terminals.
Alan
Alan
Yeah, that makes sense- guess I was over thinking it. Thanks!
