[SOLD] 1968 1969 small block 340 engine passenger side timing marks chain cover 2946797
bbrroowwnn
never re member
Drums, PA
this is a 2 year only timing chain cover for a small block....has the timing marks on the passenger side which will work for all pre-1970 small blocks however this is the 1968 1969 model year which were the only 2 years they were molded into the cover itself....the earlier years used a bolt on scale which bolted to the timing cover bolts....So even though it would work on earlier year small blocks, it is truly only physically correct on the 1968 & 1969 motors...very hard to find.....part number 2946797 and has the "69" date code stamp......75.00 shipped to anywhere in the U.S.?...postal M.O. works for me
