Mark69cuda
Active Member
I purchased this car and don't have time to finish it. The car is a 1968 with a 1969 grille and holes filled on the body. This car has the best of everything. It has been rotisserie painted and is as clean underneath as it is on top .Now for the good stuff .The car has been tubbed and has a Dana S60 narrowed. It has a 11.5 tire under it now and could fit bigger. The car has a full S&W cage with frame rails tied. Has the complete Magnum Force front suspension with Wildwood disc brakes all around. QA1 shocks all around .Fuel cell and and complete fuel system installed.battery located in trunk .Has transmission cooler and fan mounted in the back under the car. It has a bullit dash and gauges installed .Bullit steering column, BeCool radiator, car is completely wired and ignition system, It has a lot of new glass and new weather stripping installed. I do have a few pieces that still needs installed that I have .new head liner and carpet also come with. The fenders are fiberglass and I have a fiberglass hemi hood and fiberglass bumpers that comes with. I don't have a title. I was going to drag race it or you can get a title buy taking it to a enhanced inspection station and making it a street rod. The transmission in the car doesn't go with but I will sale with for $2500 or $3000 without.it is a brand new Cope transmission with manual valve body and Ptc 8 inch 5000 stall. I know I am forgetting a lot. All you need is motor and transmission and this car would be done . $ 16500. Probably almost 30k invested Sorry my pictures such .I will try an get better ones or come see it you won't be disappointed
