1968 383 hp manifolds
robs 67plymouth
motown graffiti crusier
Manteca CA
will these fit in a body 440 build ?
Since I couldn't identify the part number, I am not certain, but I really doubt it. They are B-body yes?
im not sure if there b body i sent the an email and asked what they came off of. the right one is 383 magnum 1968-69 Right 2806900
Unfortunately I can only identify part numbers, not casting numbers. I do know the casting number for the A-body should be 2863900.
Unless the pic is confusing me, the bend by the flange on the drivers side is not flat enough to be A-body.
The right hand manifold that you list is a 1967 B and C body 440 HP
Also right hand 1968-69 B and C body 440 HP and 383 HP (RR and GTX)
Hope this helps.
Not likely that this will work on an A body-early or later without modification.
The 67 up A body Big Block cars had unique manifolds.
