Hello,
Is there any way to tell by just the VIN that a 68 Barracuda is a Formula S?
The engine code is a P
Thanks
Because it has a 340, it must be a Formula S because the 340 was not available in the standard model in 1968, is that correct?Yes, P would be a 340...
Yes, if it came with a 340 or 383 that year, it was a Formula S...
Not as far as I know. Mine don't. The formula S option should also show up if you decode your fender tag, which you can do on a couple free websitesFor a 1968 Barracuda, do the last 6 numbers on the lower right of the fender tag need to match the last 6 numbers of the VIN?
