1968 barracuda front disk brakes HELP finding correct pads
BIG-B-Barracuda
CALIFORNIA
Hello guys I have a 1968 barracuda notchback
Previous owner wasn't much help with mods done to car but did say it was converted to disk brakes - I need help in what brake pads to get. What model would I buy for? I'm a little lost here . . .
Thanks again in advance - :wav::wav::prayer::glasses7::prayer:
You will get asked. Big bolt pattern or small? Small would indicate Kelsey Hayes brakes. Big would indicate a conversion. Are the calipers in front or on the back of the discs? Someone here will know what you're after.
Your going to have to post a picture of the calipers for anyone to tell you what type of brakes were used on the conversion onto your car.
1. Factory 4 piston calipers from the 65-72 A body's.
2. Slider Calipers
3. Pin type calipers.
Lots of brakes could have been used, and will work.
