1968 Barracuda Manual Transmission neutral Safety Switch
ns1rm21
Hello everybody. Does a 1968 Barracuda with a manual transmission have a neutral safety switch or a clutch safety switch? If so do you have any pictures?
No neutral safety switch on a 68’ barracuda for manual trans that started in 1970
Probably has an automatic starter relay. Just ground the "G" terminal. Factory manual trans relays had the "G" terminal folded over and soldered (maybe welded) to the relay case.
Thanks for the reply.
I’m doing a Super Stock clone and after looking at parts books and service manuals I just found it odd that they did not have one. I just wanted to make sure I was not overlooking something. Thanks again, Troy
