4 440magnum Well-Known Member Joined Aug 27, 2012 Messages 68 Reaction score 2 Location Maple Ridge, B.C. Apr 10, 2014 #1 Hi. I've seen these pieces listed as upper and lower. Is'nt it the same piece just flipped around? Thanks in advance for your input.
jaws I put the fun in dysfunctional FABO Gold Member Joined Sep 11, 2006 Messages 6,221 Reaction score 7,122 Location Strasburg Colorado Apr 10, 2014 #2 nope they are different, I also have a set from a fastback, that for some reason will not set flush on my ragtop.
norshorblufish By the Big Water Joined Dec 1, 2007 Messages 2,457 Reaction score 1,349 Location Duluth, Minnesota Apr 10, 2014 #3 I went and measured mine the upper piece is 3 1/8 inches wide plus it has sightly more of a bend. More like a kink than a bend. The bottom is3 3/8 in. wide. View attachment IMG_4942 (800x600).jpg View attachment IMG_4943 (800x600).jpg You can see the different in the bend(kink).
4 440magnum Well-Known Member Joined Aug 27, 2012 Messages 68 Reaction score 2 Location Maple Ridge, B.C. Apr 10, 2014 #4 Great info. Thanks
R RedFish Well-Known Member Joined Sep 5, 2007 Messages 25,850 Reaction score 5,348 Apr 10, 2014 #5 The 67 trims can be switched around if you're not a purist. Upper and lower on 68 are not close enough to the same for a switch.
