1968 Dart Oval Ramcharger single carb air cleaner install.
ecarpen68
Member
New Jersey
I have a 68 Dart GT with a 440RB SINGLE CARB. I would like to install the Dodge Oval Air Cleaner. I have seen a few Darts on line with this set up. What is the procedure to Install. The air cleaner sits high cannot close the hood.
the height of your intake might make this a non-starter.
what intake are you running?
If anyone has performed the installation of a ramcharger air cleaner install on a 1968 dodge dart, I would like to hear from you.
Are you sure about the baseplate. The simple way to check 440 vs 383 base is put it on a flat surface. Front edge basically touch the flat surface on a 440 baseplate. 383 will be 1/2 inch above surface IIRC.
The only other way to make it shorter is to trim the throat that sits on the carb.
Some measurement info
Nick's Garage - Air Cleaner Identification
