[SOLD] 1968 Dodge Dart 2 door no post
darto
Petaluma Ca
1968 dodge dart 2 door GT
Vin and fender tag on request
Original a FF1 with Green bucket seat car.
No Engine or Transmission
Registered until August 2015
Has plates and stickers
Clean title
Title says odometer has exceded mechanical limits- rolled over
Stated on title below mileage
When it had an engine and such it turned heads and gets lots of compliments.
Was a running and driving car 1/5/15
Has drum brakes
Has a stock tank in it now.
New Tires front 205/70-15 and back Mickey Thompson L60-15 both are nearly new with less than 500 miles.
Spring relocation kit to fit bigger tires
8 3/4 rear end
Sure grip 3.55 gears
Sub-frame connectors
has been mini-tubbed 3-inches or so
Air shocks in rear
Chrome- The front grill has been painted but is straight, the rear panel needs a good buffing and cleaning. The rest of the trim has pitting in it but has cleaned up as shown in the pictures.
Body is straight WITH NO ROT!
floor pan and right rear quarter have been replaced at some point. Work is driver quality.
At some point the firewall was cut behind the distributor about 4 x 6 inches, I have been working on a patch for it using another piece of a firewall, but cant weld in in as the house wont support the welder.
The floors are good except for an area that has been cut for a floor shifter install.
Fiberglass front fenders both left and right
Front and rear fiberglass bumpers
Fiberglass 6 pack hood bolt on with front hood pins
body is in great shape,
Paint in good shape has a few scratches and one or two small chips . (Good Driver paint)
Black Vinyl stripe has a small tear in it.
Lights, turn signals brake lights worked when running
Wipers work, just not attached
Dome light works
trunk light work except switch is broke.
Interior needs work, such as seat recovering, I would consider the seats as cores, the fabric is dry rotted they are bench seats
needs headliner,
Door panels are nice and the carpet is ok (generic carpet), though if doing the interior id replace
Glass is in good shape
Lots of other new parts!
Suspension is worn and could use some TLC-
Door locks need to be replaced-frozen?
If you are serious and want to inspect it please contact me and we can set something up.
I may be able to deliver after payment if your somewhat close +/- 500 miles from 94066 for a fee.
If you have any questions let me know and ill answer them. I'm sure forgetting something
Asking 7000 or best offer, I am motivated to sell.
Car is located in San Bruno Ca 94066
Thanks,
Rob
I have added more pictures of the trunk and the cut in the firewall I removed the trim around the radio/heater area that was glued on, and you can see it has been cut.
more pictures of the car as it sits today.
Bench seat is included but needs recovering bad!
Price Drop to 6500- open to reasonable offers
Price drop 6250 or best offer
Will do partial trade for an A body 8 3/4 rear and cash
