1968 Dodge Dart GT Convertible Latch Pin
Mopar Body and Trim
  1. Alexmorrison64
    Alexmorrison64 1968 Dodge Dart GT Convertible
    2
    0
    Jun 11, 2016
    Arlington, VA
    Local Time:
    11:06 PM
    One of the pins that holds the latch in place has gone missing. There are two of these pins on each side. I have been searching for a replacement pin (would rather not replace the entire latch). Any ideas on where I can find a replacement pin? Have searched on ebay and sites like classic industries and other mopar sites.
  2. burdar
    burdar Owen's Dad
    1,232
    282
    Aug 15, 2013
    Iowa
    Local Time:
    10:06 PM
    Try the convertible section. Lots of people have boughten new latches. Maybe someone has their original ones laying around that they would send you. Also, maybe a picture of the latch and where this part goes would help also. I can't place where that pin is by the picture you posted.
  3. dadsbee
    dadsbee FABO Gold Member FABO Gold Member
    1,070
    2347
    Nov 25, 2020
    Penetang, Ontario
    Local Time:
    11:06 PM
    'tis what the Want To Buy section is for... you might be amazed how quickly a member says "I got one" !
    • Agree Agree x 1
    • Dana67Dart
      Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
      7,420
      5057
      Jul 16, 2017
      Northern Colorado
      Local Time:
      9:06 PM
      Post some photos of where the pin is supposed to be. Im having a hard time seeing the part you posted and where it woukd fit.
    • Jim Lusk
      Jim Lusk Well-Known Member
      5,214
      1597
      Mar 8, 2006
      Fresno, CA
      Local Time:
      8:06 PM
      Yeah, I don't see where this pin goes, either. New latches have been CHEAP at Year One (the only thing they have that is cheap). Somewhere I have old latches. One that is a little busted, but most of that stuff is really hard to find right now. I have new latches for my GTS.
    • Dana67Dart
      7,420
      5057
      Jul 16, 2017
      Northern Colorado
      Local Time:
      9:06 PM
      The knurl says it goes into hole. My oem locating pin on my latch is more pointy and i think it is cast.
      Im guessing the OP is referring to the pivot pins
      • Agree Agree x 1
      • Dana67Dart
        7,420
        5057
        Jul 16, 2017
        Northern Colorado
        Local Time:
        9:06 PM
        Now that i think i have figured out what you are looking for...
        Try McMaster Carr, Ace Hardware.
        You might have to machine one yourself.
        If (like me) you do not have a lathe, you could get some bar stock and chuck it into a drill and use a file to shape it. If you use staineless (not sure how it would cut with my method) you could polish it after so it looks a bit more chromed.
        As for the knurling, you might have to come up with some other keeper setup. Maybe a set screw (use caution, cast potmetal is brittle)
