1968 Formula s 340 Here we go again
Nice find! Those valve covers look just the ones I recently fixed up and painted to match my car. I also don't know who made them, but I like them a lot!
I have the original radiator out of my 68 That you can have for $100 shipped. It had a small pin hole in the top tank which I soldered but decided to go aluminum instead. Both hoses connect on the drivers side. Let me know
So I got a good and warm yesterday for the first time and the top of the radiator seem is been butchered with some two-part epoxy and nobody in my town does radiator repair and I’m not buying a $2500 Glenray for this thing so until I find somebody to fix it I guess I’m gonna have to try and fix it myself or get one of those crappy aluminum jobs for 150 bucks oh well
Just get a 22 inch aluminum one
Yeah, I don’t think the 26 even came in our cars unless it was bb or hemi i think.
was just curious in case I found one.
sucks I got a good radiator. I can’t get it repaired from somebody local.
Back in New York there was radiator shops every 5 miles
Around where I live all the radiator shops closed. The one that re cored my original 15 years or so back guy retired shut the shop down.
I guess with the high cost of shop rent and online stuff from “china” beats the little mom n pops out of business.
What a shame
There was one here but its not correct
!!!!!!!!!!!!! YOU ARE IN LUCK !!!!!!!!!!!!!!!!!!
That IS that the tag to the car, it isn't the tag that was in the listing.
This tag IS for a 68 340 4-speed Fastback
To confirm you just need to compare the SO number to the core support number.
Should be B8B 102798
Alan
Alan
Al, I didn’t even check the tag when I got the car, so I’m a knucklehead as much as the seller is.
It sure is a BH29 tag!
where are these numbers? I gotta match it on the core support?
Are they right behind the radiator?
Man i owe you one!
Man i owe you one!
The number is under the coolant decal about 8" from the driver side fender bolt.
There is a second one in the rear under the trunk weatherstrip near the driver side hinge.
Alan
Bought n LD340 intake cleaned it up
Going to use my 4732s on it.
Also found a 1406 as backup.
Removed old intake. Started detailing under the hood a bit
Got the passenger exhaust pipe off after soaking and heating the studs it broke anyway, all cleaned up ready for reinstall. Still have to finish pulling the manifold to fix the stud stuck on that next.
Also radiator from Ron arrived looks good its a 3 row 031 mine was a 2 Row. Have to wait and test it when she gets running thx Ron!
Intake gaskets i ordered were wrong brand from ebay seller. ordered from Autozone locally instead.
Got the intake on and the radiator in.
My carb is a acting up tho.
Dumping gas big time. Giving up on it.
Gotta find a new carb.
Found a set of A body tail pipes for $25 knocked the tips off ready to go.
Ordered full set brake lines “ inline tube” and new centric drums. All the brakes and wheels cly look usable.
I found a set of exhaust adapters to put the tips on because they’re 1-7/8 to 2-1/2 tailpipes no local exhaust shops here that are easy to deal, so clamping for now, get them welded later. Yes 2 broken left hand studs i have to order.
Still Looking for a carb.
Picked up an Air cleaner and Fan.
Moving right along!:thumbsup: Definitely look for or make a shroud. Heater core bypassed for any reason?
I would be tempted to move the fuel line away from exhaust manifold. They usually come up by oil dipstick.
Fyi , I'm not nitpicking
Yeah, probably does go behind the alternator correct, I didn’t notice how close it looks now that you brought it to my attention. It’s further away than it looks, but I’ll move it. I got rid of the exhaust leaks by the manifold fixed all the broken bolts. I decided to keep the mufflers for now they’re pretty shot and have a couple holes in them, so I have 18 inch replacements
but for now they work for me.
I’m in Arizona everybody’s heater Cores are disconnected, so until I drop the heater box, I will not know whats wrong with it.
I may test it and put it back on, but I will never use it here. Or maybe buy a new one after i clean the box up.
Man, every time I touch anything on this car it drops tons of rust.
My garage garbage can is very heavy ha ha ha thank God I’m not restoring it cause it would need a lot of sheet. metal.
A lot of you guys are gonna hate this but I patched each floor with sheet metal and rivet patches. I don’t have a welder and I’m not gonna give it to somebody to do just to make a driver, but here are some pictures of the patches, I’m gonna por15 over them And throw Carpet down, Not trying to hide anything just patch it for now so there’s no holes. The drivers rocker is gone, but they do make it repop.
I forgot to chk the climate you're in and not needing the hc. If u decide to redo the heaterbox, and hc is toast, get it redone. The newer ones are a crap shoot if they fit or not. Good job on floors, like Rustys thread "get it runnin n drivin" :thumbsup:
