stuka1166
Member
1968 Plymouth Road Runner
Build date: 12/1/1967
Lynch Rd. Plant in Detroit, MI
RM21/Post Car (Coupe)
Non-Décor Package (No Trunk Finish Panel-No Horn Ring)
Radio Delete
Matador Red (PP1)…Repainted (No Date)
Interior: Black/Restored (12/2015)
(New) Headliner-Trim
(New) Dash Pad
(Restored) Dash Board
(Restored) Dash Frame
(Restored) Steering Column/Manual Steering
(New) A-Pillars
(New) Rear Package Tray
(Restored) Factory Gauges
(New) Fuel Sending Unit
(New) Switches/ Levers
(New) Period Correct Tachometer/Oil Pressure Gauges (Chrome)
(New) Pedal Pads
(New) Window Cranks
(New) Carpet
(New) Front-Rear Seat Upholstery
Exterior: Recent Upgrades (12/2015)
(New) Door Seal Weather Stripping
(New) Trunk Seal Weather Stripping
(New) Window Cat Whiskers
(New) Roof Rail Weather Stripping
(New) Headlight Harness
(New) Side Marker Lights Assemblies
Drivetrain:
**Numbers Matching Engine/Trans/Body**
Engine: 383 Super Commando/Mild Rebuild (No Date)
(New) “Fire Core” Electronic Ignition (5/2015)
(New) Edelbrock Carb (5/2015) w/ (Electric Choke)
(New) Exhaust Manifold Gaskets
(New) Stainless Exhaust w/Tips (5/2015)
(New) factory metal fuel line w/built in filter
Transmission: 727 Torque flight (3 Speed Auto)/ Rebuilt (12/2015)
(New) HD Clutch Plate
(New) Bolt in Sprag
(New) Turbo Action Valve Body
(New) Torque Converter
Front End: Rebuilt (5/2015)
(New) Upper Control Arms
(New) Bushings
(New) Ball Joints
Disc Conversion (BAER)/Power Brakes
(Rebuilt) Rear Drums
(New) Master Cylinder-Brake Booster
(New) Alignment
Rear End: Rebuilt (10/2015)
(New) 742 Case
(New) 7290 Chrome Moly Billet Yoke
(New) Bearing Kit
(New) 3.55 Gear
(New) Eaton Truetrac Posi
Wheels/Tires: Excellent Condition
Magnum 500 Wheels
Mickey Thompson “Sportsman ST” Tires
Car is NOT a nuts and bolts restoration…But a VERY NICE driver
Asking $31,000/Trades Considered...Classic Mopars/New SRT Challengers
Radio Delete
(New) Dash Pad
(New) A-Pillars
(New) Pedal Pads
(New) Window Cranks
(New) Carpet
Drivetrain:
(New) Bolt in Sprag
(New) Bushings
(New) Ball Joints
(New) Alignment
(New) 742 Case
(New) Bearing Kit
(New) 3.55 Gear
Magnum 500 Wheels
