[FOR SALE] 1968 Plymouth Valiant (Rear End Damage)
Varment
Rochester Hills, MI
Rating - 0%
0   0   0
1968 Plymouth Valiant for sale $850
The good:
- 318 rebuilt 4 years ago with 15k miles on it.
- Vehicle runs and moves on its own power (I do not recommend driving home as the exhaust is bent at the manifold which causes it to rub against the inner tie-rod)
- grill/hood, front fender panels, doors and glass in good shape.
The Bad:
- Rear ended two years ago.
- Heavily bent frame over rear axle
- Trunk, rear right body panel, front left A-pillar all heavily bent
- Right bank exhaust pipe below manifold heavily bent
I purchased this car in 2003 and it was used as my daily driver all the way up until 2014 when it was rear ended bending the frame. This car, along with this forum, is what gave me all the knowledge I now have of mechanics. Unfortunately, I am in a position where I cannot devote the time to fixing her up for a second time and must let the Varment go. I understand the amount of damage on the car is pretty severe and do not hide any of that in this post. The price reflects what I feel is a good deal if the car were sold out for the motor, panels, and components.
I've taken it to frame shops and all state it is fixable damage but still too much for what I can put into it.
I will not ship the vehicle. Vehicle will not come with battery. I can put one in it to show that it runs though
The good:
The Bad:
View attachment 1714995191 View attachment 1714995189 View attachment 1714995190 View attachment 1714995196 View attachment 1714995195 View attachment 1714995194 View attachment 1714995193 View attachment 1714995197 View attachment 1714995198
where are you located?
You're probably posting from your phone? Turn it sideways and you should see his location of Rochester Hills, MI under his avatar. If you click on the location, you'll get a map too!!
Thanks for answering 6pk2goDemon!
Hemitheus (awesome name btw!), you are not even an hour away from me, so let me know if you want to check her out anytime.
hahaha i WAS holding my phone the wrong way. Thanks!!!
I work in Farmington Hills...Ill PM you
