I have a 1969 Valiant and I'm putting in a factory console and a factory automatic on the floor. I need the piece of linkage thats under the car that runs from the ( torque shaft to the transmission control lever and it is called the lower rod ) I'm using a 904 and I'm not sure if that makes a difference. Also I was told that red fish has a diagram of where the console brackets get welded to the floor. Also I'm putting the plates under the bucket seats, I believe they go over the holes closest to the tranny tunnel, Is there a specific way to weld them in so they are correct.....Thank You Webby.
