[SOLD] 1969 Barracuda Formula S PARTING OUT!!
Capt46
Staten Island N.Y.
No Motor
No column
No transmission
Have a 8 3/4 rear with 3.23 gears suregrip $1,600 no springs.
Have all trim rear window $800
Front windshield trim $250
Doors $200 each no glass broken inside
Bucket seats with headrests headrests burnt, no gauges
No dash
Front fenders nice $900 each
Hood nice $200
Header panel $200
Formula S complete Grills $1,500 each
Disc brakes Kelsey Hayes $300
No pedals
Bumpers and brackets $250 each
Ask for your needs thanks
Prices are for a starting point.
Is the hurst shifter with linkage and mounting plate available in on Long Island would be interested in some other items brakes trim ty
master cyl,proportion valve ,is it power steering,alt and brackets w/o ac
Power brake booster is a keeper,
I’ll be removing the manual master cylinder I have an additional proportion valve from the 69. I have a power steering box that’s coming out of the 68 with the power steering pump from the 318 but I don’t think the pump is strong enough because it was weak on idle and worked well under more of an acceleration, I will have the other brackets and alternator after the installation of the 340 stay tuned. Pictures today
sure doing a 340 4spd swap into my 69 6cyl 3spd dart
have the disks
doing ps swap too
have a box
trying to stay oe ....might need wiring harness too
pm me when your done still a year or two away
Darn everything i needed
Are you keeping ac on your car
Good luck with it
I need valve covers and air filter if you don't use them
Yes it will have,
4 speed
Power disc brakes
Air conditioning
Headrest buckets
Tach 150MPH SPEEDOMETER
PAINTED RIMS WITH POVERTY CAPS
DOOR GUARDS
WHEEL MOULDING
SPRING SPECIAL MOULDING
TINTED GLASS
HEAVY DUTY SUSPENSION
8 3/4 3.55 sure grip
Power steering cooler too
Pm me with whatever you have left over
Yea .....I can take my dreams away
You sold the proportioning valve?
Or still need it
