1969dodgedart
Big Block 440
Yes I do , a disk I bought . Printed off from there.To start, do you have a factory service manual? You can download them free from MyMopar
The radio connector "a clue" .......all orange wiring is dash dimmer controlled instrument panel lighting, controlled by turning the headlight switch knob
So far as the glove box, you say the harness way butchered.......if there is nothing hanging loose over on that side, someone may have hacked it off
Ok so plug into the red/ white side of the T radio connector for power to new deck , one issue solved . ThxYes I do , a disk I bought . Printed off from there.
Ok , thx. I wondered if the key switch light and glove box light didn't come std on this car . Thats why I cant find where to connect them. I will look for that wire though, thx.If your glove box has the optional light, the single wire light fixture plugs into a pink wire in the loom.
