1969 Formula S owners needs help with Variable Speed Windsheild wipers
Section 23-67
In adobe pdf, page 1125
Page 564 adobe. Section 23
Oh my....do I have a lot to learn~Thank you.... I did find the pages, and our page numbers match. I've printed them out and believe I now know the correct part numbers of the pivots and crank.
LH Pivot S/B P/N: 2857935 Mine is 2857935 ! :)
RH Pivot S/B P/N: 2857934 Mine is not known! :(
Drive Crank S/B P/N: 2822272 Mine is not known:(
Larry it looks like in your pics you have drivers side in the right in your pics?
Also your bracket/link on the left in your pics. I dont have that in mine?
Looks the same to me Steve,, everything is as it was when I removed it. The grooves in the arms face each other and the tie rod is on the lower pin with the drive rod with the kink in it (toward the wiper pivot) goes on the top pin as installed on the car.
the motor needs to be in park position before the wiper arms are installed or it'll be wiping paint some where. pic is where the motor arm parks.
Well well...My RH and LH Pivot's are the correct part numbers. Assuming the drive and connection links are correct, I need to find out why the wipers are not parking. Thanks for the tips guys!
