[SOLD] 1969 Plymouth Barracuda
Machmeter1
Dayton Ohio
For sale is my 1969 Barracuda, it still has at least 90% of its original paint. The car was first sold by Hacienda Chrysler Plymouth Inc. in California. In 1986 the car was exported to Canada and in 2019, I imported the car back to the USA. Over the last year, I brought it really close to its original condition. The engine is year and date correct, was professionally rebuilt by Kammer&Kammer Racing in Dayton/Ohio, and has less than 1000 miles on it. I also rebuild/renewed the 904 transmission, suspension and drivetrain. The quarter panels are original and "rust-free", so is the floor pan, and are the front fenders. The only part I know of that has been repainted, is the passenger door, but that was 50 years ago. The car is intended and can be used for trips. I wanted to build a “reliable” classic car, as close as possible to original and that is what I am offering here. There are no fluid leaks, no vibrations, or other issues, typically found on classic cars. The car has a clear Ohio title and is registered under my name, and insured through Hagerty Classic Car Insurance with a guaranteed value of $37.000.
About the Barracuda:
· 1969 Plymouth Barracuda
· 8 ¾ rear axle housing with Moser axles and 489 rear end - 2:76 ratio
· heavy-duty leaf springs
· newly and professionally rebuilt, date correct 318 engine – dyno tested with all receipts and photo documentation (pistons .030 over)
· newly rebuilt transmission
· new carpet, the rest of the interior is original and in very good condition
· besides the original radio and AC every light and switch works
· rebuilt and already installed RV2 AC compressor
· new Denny’s driveshaft
· rebuilt brake booster – original Midland and Ross (by Booster Dewey)
· Firm Feel power steering – Stage II
· original Kelsey – Hayes Rims 5.5 x 14 (big bolt pattern)
· 1-year-old Galaxy R1 tires
· new exhaust system (Waldron’s Exhaust)
· front suspension rebuild with PST parts
· complete new brake system disc front – drum back (Dr. Diff)
· new brake lines and hoses
· original exhaust manifolds
· new bushing on all suspension parts
· original fuel sending unit – reads correctly
· new fuel lines
· headlight relay conversion
· all instruments are working (speedometer, fuel, ammeter, oil pressure, temperature)
· all liquids new
· hundreds of pictures, organized in folders for each part section, showing every detail of the restoration
· original documents and brochures for the car
· technical literature
· a binder full of receipts – showing every single penny I spent on the car
Additional parts that come with the car:
· 1 harmonic balancer 318
· Layson’s 8000 RPM Tachometer
· Detroit Muscle Technologies firewall insulation kit
· Detroit Muscle Technologies AC heater box repair kit
· NOS driver door panel
· 1 crankshaft pulley (2 grooves) 318
· 2 AC brackets
· 2 exhaust manifold gaskets
· 1 rear drum 904 transmission
· 4 rocker arms 318
· Lubelocker Transmission gasket
· An assortment of original bolts
· 1 AC blower motor + drain hose (bolt box)
· 2 headlight bezels + key and steering column cover plate
· 1 rally cluster clock
· 1 A-pillar cover (driver side)
· 2 kick panels (driver and pass side)
· 1 3speed windshield wiper switch
· 1 windshield wiper linkage clip
· 1 emergency flasher switch
· 1 thermostat
· 1 AC blower motor switch
· 1 high beam floor switch
· 2 taillights + lenses
· 2 parking lights + lenses
· 2 Barracuda front emblems
· 3 deluxe seat emblems
· 1 seat latch cover
· 2 seat latch knobs
· 2 seat slider knobs
· 1 clock delete bezel
· 3 side reflectors (2 back)
· 2 license plate light lenses and 1 wiring
· 1 fender fish
· 1 floor rubber plug set
· 1 door hinge repair set
· 1 rear window molding fasteners
· 1 rear window seal
· 1 set original seat belts (grey)
· 1 C pillar interior light lens
· 1 thermostatic Choke
· 4 window trim moldings (short)
· 1 Carter Carburator
· 1 Square back alternator
· 1 Pertronix ignitor
· 1 Pertronix coil
· 1 original Mopar distributor
· 1 AC condenser
· 2 AC mufflers
· 2 AC driers
· 2 AC expansion valves
· AC a134 charging fittings
· Barracuda specific car cover
· there might be more parts, but not listed yet in my inventory
What needs to be done:
-Scratches and dents (showing the age of the car)
-radio and speaker are not connected
-new AC hoses to hook up the rebuilt compressor to the original AC Heater box (currently working on restoring the AC hoses and lines)
So far, I spent in total 39.313$ on the car but also sold some of the big block parts. I do not need to sell, but in the last weeks I started to lose enthusiasm and the desire for a change came to my mind. It might be my winter depression, but I experienced the same feelings after finishing an 8-year nut and bolt restoration. I know that I won’t find a 69 Barracuda in this condition anymore, but my motivation is gone. I will keep the option to reverse my decision, but at the moment I am ready to let go.
Everything above is just a small summary of all the work that has been done to the car. If seriously interested, take your time, sit down, and read my restoration thread here on FABO. It should answer almost every open question:
1969 Barracuda Fastback | Page 9 | For A Bodies Only Mopar Forum
Price: $33.000 OBO
The dyno sheet says "440 six pak" in the upper left hand corner, maybe wrong dyno sheet.
No, correct dyno sheet. Just the engine test description was not changed on the computer, but that is the dyno sheet of my engine. That is a picture of the hard copy we printed out after the final test run. I also have videos from 3 pulls at the dyno test day.
That would be a very weak 440 six pak :)
Update on the AC System:
AC mufflers and new/restored AC lines from and to the compressor installed.
Price update:
$29.900
