[FOR SALE] 1970-1988 Dodge Chrysler Plymouth Mopar Floor Shift Steering Collars Good used look
Big.J.007
1970 Plymouth Duster
Hill Country, Tx
I have for sale a very nice good used set of 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987 1988 Dodge Chrysler Plymouth Mopar A B E F body floor shift steering column collars. These will fit all non tilt Mopar factory steering columns. These are great to convert your column shift to floor shift. These are used oem collars not reproductions. What you see is what i have no screws or hardware is included. The collar with tab has a hole previous owner drilled in it, you can fill it or use a plug. All threads and housings are in good condition. $135 shipped in the US. Sold 1st come 1st served no holds. Get it before it's gone.
Appears to be off an '85 model. '70 uses a different key release section.....one without the thumb lever. Also the center section that holds the lock cylinder is the '72-up style. '70-1 use a different spring loaded keeper to hold the cylinder in. The '72-collars use a lock cylinder with a round pin. As an assembly it should work, as long as you use the appropriate lock cylinder, and if you don't use the '70 version of the key release.
Some of those collars had a hole in them for the entry light pkg which included a light on the column to illuminate the ignition switch. I believe that may be why that collar has the hole. Friendly fyi.
Thank you, it is a very well drilled hole. Might be factory.
