1970 carter 4933s,Rebuild or buy edelbrock?
beck
Hi all, Its been a while but I finally got a new toy, 70 Dart swinger 340,And 1st project is the carb,gaskets are leaking and runs little ruff.Is it worth rebuilding or should I be looking at Edelbrock avs.Any and all advice .I am pretty sure motor is stock, maybe a little cam.
I didn't have an original carb like you do so I went with the AVS650. If had one, for a totally stock engine, I would lean towards rebuilding if the throttle plates and bores are in good shape.
First off, have you determined that the carb is even the reason that it "runs little ruff"?
A little discoloration at the carb seams doesn't necessarily mean that it's leaking. I would definitely rebuild the original Carter (it's already an AVS, by the way) if for no other reason than to get gaskets and seals in it that are compatible with today's fuels.
I'd use that all day long over an aftermarket carb. Automatic choke, fast idle, etc. everything fits.
Put a vacuum gauge on it first and see about how much idle vacuum it has. Adjust mixture screws for max vacuum.
Thanks to all,I have only got the car a couple weeks ago,Just when I got it home and did a good inspection, I notice the gaskets looked liked there leaking. I am going to do complete tune up on it,but wanted to start with obvious.
I would buy the Edel 650 AVS2 carb. It has two features that in my opinion improve the performance over the excellent design of the original AVS design. Improvements that the butt-meter will feel.....
[1] Annular primary boosters. These improve throttle response.
[2] The secondaries. Edel added venturiis to the secondaries instead of discharge tubes that the original had. If you look at these tubes, you will see holes along the length & in the end. The size & location of the holes varies. Rt side is different to left. Any change to the engine [ bigger cam ] is likely to change this very specific calibration & will no longer be optimal for the engine.
I have run Carter 625 AFBs & 625 AVS carbs back to back & the AFB always had better acceleration on the secondaries.
