mrhp
1970 Dodge Dart Swinger 340. Base/clear FY1 Top Banana Yellow. Broadcast sheet, fender tag. Boise ID car, pristine body, all original metal, never even a dent. Now running a pro built 440 8V. Best of everything: 1978 HP block, steel crank, stock rods, .030 over forged pistons (446), oil galleries reamed out for better top end oiling, 906 heads, Hemi fuel pump, 284 - 484 Mopar Purple camshaft, balanced, windage tray, 8 quart oil pan, Schumacher mounts, 2" TTI headers, dual 500 CFM Edelbrock 1404 carbs. Mopar Chrome box electronic ignition, Jacobs 8.8 ceramic boot wires. Running NGK V-Power Plugs 3332 XR5 showing perfect burn. Built 727 with mild stall, fresh 3:55's (Born with 3:90's), speedo gears matched for accuracy. PST bushings. Wrapped mini starter. Just Dash's did the pad and Mr G's did the gauge bezel. New console ashtray lid. OEM mint tapered defroster tubes. DrDiff 15/16" master cylinder for better pedal feel. Also did new lines and distribution block. Radio powers on but no volume. I've owned for about 6 years; bought from the 2nd owner who owned it for 38 years and knew the car from day one. In La Mesa CA 91942. PM or email with your number if you have questions. $35,000. Last pic is from back in the day.
Fender Tag breakdown:
1970 Dart Swinger 340 – LM23H0R215106
L: Model, Dodge Dart
M: Price Class, Medium
23: Body Type, 2 Door Hardtop
H: Engine, 340ci V8 4bbl HP (LA motor)
0: Year, 1970
R: Assembly Plant, Windsor, ON (Canada)
215106: Sequence Number (115106th Vehicle Built)
E55: 340 CID 4 barrel V8 275hp
D32: Heavy Duty Automatic Transmission
FY1: Exterior Color (Top Banana Yellow)
H6X9: Trim - High, Vinyl Bucket Seats, Black
TX9: Int. Door Frames
215: Build Date: February 15
092993: Order number
V1X: Full Vinyl Top, Black
C16: Console w/Woodgrain Panel
C55: Bucket Seats
J45: Hood Tie Down Pins
M21: Roof Drip Rail Moldings
M43: Grille Trim Moldings
N41: Dual Exhaust
N42: Chrome Exhaust Tips
V88: Transverse Stripes, Deleted
Y05: Build to USA Specs
END: End of Sales Codes
Second owner added a mint OEM Go Wing many years ago.
0: Year, 1970
C55: Bucket Seats
N41: Dual Exhaust
