1970 dart swinger 340 tail lights
Jarod340
Active Member
Petaluma, ca
I have a 70 340 swinger 4speed. The tailight housing wiring is crap and where the bulbs sit is rusted out. I'm looking for housings with good wiring that plugs into the rear harness! Does anyone know of a place that sells this or can make the new wiring connection? Thanks
I already bought that one. That part number is just the rear harness. I need The wiring in between rear harness and tail light housing...the exact wires and bulb sockets that are shown in the pick....cant find them anywhere
If you take your time you can replace/rebuild the wires yourself
The clips can be removed from the grey connector (your holding) use small screwdriver
Solder in new wire using old clip
In the bulb holder the base holds the wire end in with a lump of solder
Push the wire out from the back of the socket Just remember the spring
