1970 Dart Swinger Project
Mopardeacon
Active Member
Norther California
Rating - 0%
0   0   0
For sale: 1970 Dodge Dart Swinger project car...was 318/904 a/c car red w/ white vinyl top car, now has 1968 dated coded 340 w/ 727 trans, motor has "J" code heads w/ stainless valves and mild port work & hard seats, 270 comp cam, tti headers, performer air gap manifold and brand new 750 performer carb, mopar performance electronic ign w/ orange module, K&N air filter & mopar performance valve covers, Hurst vmatic 2 shifter, 83/4 fear end w/ two sets of gears (1) 741 case 276:1 (2) 391:1 w/ 489 case & cone type suregrip (installed in car but would replace gears as they have a chipped tooth and are very noisey) new rear axle bearings, new monroe gas shocks, new superstock springs & pinion snubber, has 74 dart lbp disc brakes and steering column, fiberglass hood w/ six pack hood scoop, autometer tach w/ shift light (needs hooked up) mechanical oil pressure & temp gauge, new front tires and alighn, vinyl top has been removed and body work begun, car runs and is drivable, needs paint & body work, only rust is pin hole in spare tire well, interior is black w/ bench seat and in better than average condition for a 41 year old car, body is fairly strait, bumpers good, lights & heater working but needs wiring properly repaired and tlc, Lic till July 2011 and pink in hand, car has great potential, would like $4000. Joe (530) 403-8893 car located in Nor Cal.
Car is almost rust free, fenders, floor, pillars very good only known rust is pin hole in spare tire well, when I stripped off what was left of vinyl top was rust free other than some very light surface rust, even under the rear wind seal which is in bad shape the metal was surprizingly good, if you need pic's of any certain area let me know I will try to provide.
Joe
