1970 dart swinger v-8 auto car parting out complete rust free car
joel
EDINBORO PA 16412 USA
fenders -rust free very good cond. 250.oo ea
drivers qtr panel will cut to spec includes wheel house 250.oo--pass side is hit and dented
drivers door perfect rust free 150.oo without glass--pass side is dented
bumpers perfect cores need rechrome 50.oo ea
bumper brackets rust free 50.oo pr
grille good cond but not perfect 75.oo
front fender extensions exc. 50.oo ea
front fender extension chrome fair cond some pits 20.oo ea
rear qtr panel extensions 20.oo ea
tint glass door glass 50.oo ea
tint qtr glass 50.oo ea
tint rear window 100.oo
hood saftey catch 10.oo
hood release 20.oo
vinal roof trim complete all 6 pcs 125.oo
drip rail trim 100.oo-all
rear trunklid trim in good cond no dents -minor scratches 40.oo
rear qtr pnael extension trim exc. cond 25.oo ea
sidemarkers excellent lenses chrome good but not perfect
-minor pitting , complete with backers and wiring 50.oo ea
tailight exc cond no breaks includes housings all rust free in exc cond 150.oo pr--will seperate
tie bar 25.oo
pass headlight bezel 50.oo
interior--------------------------------------------
bench seat without headrests needs recovered 100.oo excellent tracks
headrest with chrome band no cracks -black nice - 150.oo
rear seat set excellent no cuts or rips excellent- black - 100.oo pr
dash wiring harness for A.C. 100.oo
sunvisors black loose stitching 25.oo pr
seat belt set for bench seat good cond black
150.oo -all
gl box door 20.oo
defrost vents 20.oo ea
rear upper steel door panel 15.oo ea
headliner bows 50.oo-set
dome light assy 10.oo
engine compartment
frame rails front clip frame section, inner fenders a.c. firewall excellent rust free350..oo
v-8 torsion bars 50.oo pr
power brake booster assy 100.oo
headlight wiring harness 50.oo
under hood air conditioning parts /compressor/lines ect. 100.oo-all
THIS IS A NICED RUST FREE CAR WITH
GOOD TITLE AND TAGS WILL SELL THE WHOLE CAR AS A RESTORATION PROJECT it is a shame to cut it up , but its worth more in parts
located in n.w. penn
16412
i have lots of pics
If you cut it up interested in the radiator support.
I need the passing/kickdown linkage bolt-the one that screws into the trans for the kickdown leverage. I need the one where the pin is close to the trans side and not the one where the pin hole part is out at the far end. Im in NW PA also-15857 St Marys.
the floorpans would be to large to ship
reproductions would be the way to go ,
the transmission bolt , is that for a 904 or 727
a 904. I also need the "clip"?? that holds on the ball end joint on the linkage. Its just a metal round tension type holder that holds the ball in the linkage hole. Make sense? Mine has 2- located at the fulcrum point by z-bar and the other is at the back of engine area at the top of the linkage arm that runs from intake swing arm assembly to the trans swing arm assembly. Make sense??
hey joel, i know you said the pass. quarter was hit, but is there a good patch around the wheel opening? thanks, dave.
