[FOR SALE] 1970 Dodge Dart 440
Buckeye440
Ohio
Rating - 0%
0   0   0
Some unfortunate things have happened to me that are making me seriously consider having to sell my 1970 Dart. I have not had the chance to enjoy driving it because I had been focusing on getting the car how I wanted it before I teased myself with driving it before it was all finished. I just had both carbs professionally rebuilt by a shop owned by a local Mopar mechanic. That being said the engine does not consistently run and I am not exactly sure why, nor do I have the time or resources anymore to dedicate to the car. It is a solid car, no rust areas other than a couple very small spots in the usual fender areas. Underside seems to be Zeibarted as well. All trim included, as well as old MSD 7AL2 ignition box. The car is located in Youngstown, Ohio. Any and all questions and comments will be greatly appreciated! I'm asking $8,900 or best offer. Here is the list of the things that have been done to the car:
-440 with 915 heads making 11.5:1 compression
-509 cam
-MSD 6AL2 ignition box
-MSD Blaster SS coil
-MSD wires
-Dual quad Weiand high-rise intake
-2 750 cfm Holley carbs
-Mopar valve covers
-727 with 4000 stall
-Cheetah SCS floor shifter with trans brake option
-Front disc brakes
-11 x 2.5 drum big bolt rear brakes/axle
-Super stock rear springs
-150 psi air shocks in rear, newer in front
-Traction bars
-12 gallon fuel cell in trunk
-Trunk mounted battery
-Pro Port 2.5 inch headers to 3 inch exhaust exiting in front of rear wheels
-7 quart Milodon oil pan
-Autometer Big Face tachometer
-Autometer fuel, voltmeter, water temperature, oil pressure gauges
-BG electric fuel pump
-8 3/4 rearend
-Good chroma blue paint
-Black vinyl top
-5-point harness
60 YEARS OLD NOT A TIRE KICKER PLEASE GIVE ME A CALL IF STILL AVAILIBLE THANKS DINO (phone and e mal removed by moderator) contact seller through a personal message.
