I tried to install my steering column last night but I was not able to get the coupler to reach the steering box. I tried to pull on the steering shaft to see if it was collapsed but there was no movement. Everything looked intact when I had assembled the column. This is the original steering shaft and column that came out of the car and the original power steering box.
I have the 2 lower mounting plates installed under the raised lugs of the steering column tube. Should these be mounted above the lugs? Sorry I can't provide pictures but him at work right now.
