rp23g7
Hey guys, we have decided to sell our
1970 Plymouth Duster
Original Slant 6 survivior car. One owner car, special ordered by a (now) little grey haired lady from S.L. Savage in Seattle.
We are the second owner.
the original owner had every single service record from when the car was new (see cut and paste of history below).
Everything works, yes, even the fuel and temp guage, Original owner took car of everything, rust, interior rips etc.
We put a new windshield in it a few months ago. We also have a new rear bumper coming for it.
The engine and trans have been rebuilt in 1997, and have ony had 30,000 miles put on it since then. The rear differential has been rebuilt in Jan 2010.
It has a aftermarket stereo, but we still have the original radio. It has Modern Rims on it, but we still have the original body color rims, not sure where the flying saucer hub caps are though.
I also put a brand new (not rebuilt or new rebuilt, bought from Slantsixdan) Holley 1920 on it, new engine wiring harness, new battery, new engine harness, new positive and negative cables, new KYB Gas Adjust shocks and i have a new set of .92 torsion bars that i have not installed yet.
Partial sample of car service history and pics below more if interested.
Asking $8000
steve
1/18/1974
36,141
timing adjust, adjust right door
9/9/1974
41,375
front end alighnment
12/30/1974
44,408
tune up, valve adjust, adjusted trunk latch
2/26/1975
air filter
2/28/1975
heat riser and gasket replace
3/1/1975
46,440
adjust torsion bars? Oil change
1/8/1976
56,251
cap, rotor, cond, points replaced, fuel filter, plugs, pcv
6/14/1976
60,786
points rotor, cond, plug wires, plugs, ps belt, alt belt, pcv, muffler, tail pipe, oil change
11/26/1976
upper and lower hose, heater hose, clamps, thermostat, anti freeze, battery,
12/8/1976
69,890
outer wheel bearings, brake job, turned drums,
3/11/1977
u joints replaced, oil change,
6/8/1977
replaced water pump
8/10/1977
tune up, , oil change
10/7/1977
shocks replaced
11/16/1979
tune up, oil change
11/20/1979
103,190
new carb, adjust valves
11/12/1980
110,451
tune up,
2/12/1981
112,177
replaced starter,
6/16/1981
front &rear brakes, replaced rear shocks, replaced rear drums
9/23/1981
117,861
replaced u joints
9/29/1981
117,997
alt belt, heater hoses, tune up, new radiator,
10/8/1981
172,102
il change, tune up, adjust valves
6/24/1982
new battery
6/29/1982
shocks replaced
10/18/1982
129,413
fixed coolant leak, fuel filter, plugs, points, cond, rotor, cap
2/21/1984
141,691
tune up, oil change, cap, rotor, wires, air filter, outer bearing, new front brake drums, new studs, inner bearings
2/24/1984
oil change
5/15/1984
144,359
tightend pitman arm, new wipers, new lower ball jointsoil change
6/11/1984
138,589
replaced lower ball joints, replaced strut rod bushings, alighnment
6/29/1984
muffler replaced
7/31/1984
146,000
upper and lower ball joints R&L, rf spindle, bearings, tie rod end
8/10/1984
146,771
oil change
10/5/1984
148,854
oil change, rotate tires, tire repair, anti freeze
5/14/1985
153,284
tune up, new washer pump, oil change, air filter, fuel filter, plugs, points, cond, pcv,
8/9/1985
brake light short, fixed
10/22/1985
master cyl replace
8/5/1986
164,862
cooling flush, replaced radiator, ps belt, tune up, plugs, coolant, water pump
5/24/1987
176,260
11/13/1987
180,699
rad flush, fuel filter, cap, plugs, pcv, points, cond, rotor
12/3/1987
tail pipe hanger
3/3/1989
187,639
alt belt, upper, lower rad hose, coolant, fuel filter, breather cap, plugs, set points, oil sender, thermostat and gasket, oil change
7/5/1989
4 new tyo tires
7/10/1989
maaco, supreme paint service
9/11/1989
179,197
replaced batt hold down, adjusted valves, valve cover gasket, oil change, replaced defrost tube
10/27/1989
192,681
replaced bad push rod, rocker assy, adjusted valves
12/8/1989
193,530
cooling system flush, brake inspection, 1 qt oil
4/18/1990
tune up, plugs, fuel filter, points, condesor, tail pipe and clamps, timed engine
5/7/1990
idle adjust, checked oil pressure, 30lbs hot
9/28/1990
replaced power steering pump, high pressure line, fluid
7/31/1991
replaced voltage regulator
10/3/1991
oil change, diff service,
10/8/1991
tune up, plugs, points, cond, rotor, cap, brakes f&r, rear left drum replaced, fuel filter, flasher, repacked bearings, timed
11/29/1991
alternator replaced
4/28/1992
211,871
oil change
8/14/1992
215,219
tune up, oil change, air filter, points, timed, cond, plugs, fuel filter, coil wire, vac hose
12/5/1992
216,484
replaced fuel filter,
6/22/1993
219,144
oil change, brake inspection
7/10/1993
heater core replaced
10/5/1993
220,495
tune up, oil change, points, cond, cap, rotor, pcv, plugs, air filter, fuel filter, batt cable ends, plug wires, rad cap, upper hose
10/13/1993
220,595
carb rebuild, fuel pump replaced,
1/27/1994
dent and rust repair
2/28/1994
new water pump
7/8/1994
new radio
7/25/1994
replaced oil switch.
8/5/1994
225,868
oil change,
8/19/1994
225,908
new ignition switch, new starter relay, new starter,
10/13/1994
new antenna
10/31/1994
nss replaced,
11/9/1994
body work
1/11/1995
replace rt door lock, rekeyed, dent fix, blend
4/3/1995
230,409
tune up. Points, cond, cap, rotor, pcv, fuel filter, air filter, plugs, breather
7/28/1995
233,139
oil change, breather,
4/10/1996
new front seat recovered
5/15/1996
237,771
oil change,
5/28/1996
237,991
tune up, points, cap, rotor, plugs, fuel filter, air filter, pcv, wipers, alt belt, ps belt
6/5/1996
238,080
trans service and pan replace filter
10/28/1996
239,821
replaced battery
11/11/1996
240,021
oil change, breather filter
2/10/1997
new tires
4/22/1997
241,591
f r brakes, hardware kits, front hoses, tie rod end, uca bushings, alighnment
7/15/1997
242,074
rad repair, oil change, engine rebuild, trans replaced, bored .030
10/23/1997
242,788
tail pipe hanger
8/15/1998
244,470
4 new tires
11/15/2000
250,005
new master cyl, new wheel bearing sets
8/8/2001
251,048
replaced plug wires, new batt cable ends, tune up, replaced coil, oil change
5/1/2002
252,268
replace battery
Asking $8000
steve
1/18/1974
36,141
9/9/1974
41,375
12/30/1974
44,408
2/26/1975
air filter
2/28/1975
3/1/1975
46,440
1/8/1976
56,251
6/14/1976
60,786
11/26/1976
12/8/1976
69,890
3/11/1977
6/8/1977
replaced water pump
8/10/1977
10/7/1977
shocks replaced
11/16/1979
tune up, oil change
11/20/1979
103,190
11/12/1980
110,451
tune up,
2/12/1981
112,177
replaced starter,
6/16/1981
9/23/1981
117,861
replaced u joints
9/29/1981
117,997
10/8/1981
172,102
6/24/1982
new battery
6/29/1982
shocks replaced
10/18/1982
129,413
2/21/1984
141,691
2/24/1984
oil change
5/15/1984
144,359
6/11/1984
138,589
6/29/1984
muffler replaced
7/31/1984
146,000
8/10/1984
146,771
oil change
10/5/1984
148,854
5/14/1985
153,284
8/9/1985
10/22/1985
master cyl replace
8/5/1986
164,862
5/24/1987
176,260
11/13/1987
180,699
12/3/1987
tail pipe hanger
3/3/1989
187,639
7/5/1989
4 new tyo tires
7/10/1989
9/11/1989
179,197
10/27/1989
192,681
12/8/1989
193,530
4/18/1990
5/7/1990
9/28/1990
7/31/1991
10/3/1991
10/8/1991
11/29/1991
alternator replaced
4/28/1992
211,871
oil change
8/14/1992
215,219
12/5/1992
216,484
6/22/1993
219,144
7/10/1993
10/5/1993
220,495
10/13/1993
220,595
1/27/1994
2/28/1994
new water pump
7/8/1994
new radio
7/25/1994
8/5/1994
225,868
oil change,
8/19/1994
225,908
10/13/1994
new antenna
10/31/1994
nss replaced,
11/9/1994
body work
1/11/1995
4/3/1995
230,409
7/28/1995
233,139
4/10/1996
5/15/1996
237,771
oil change,
5/28/1996
237,991
6/5/1996
238,080
10/28/1996
239,821
replaced battery
11/11/1996
240,021
2/10/1997
new tires
4/22/1997
241,591
7/15/1997
242,074
10/23/1997
242,788
tail pipe hanger
8/15/1998
244,470
4 new tires
11/15/2000
250,005
8/8/2001
251,048
5/1/2002
252,268
replace battery
