apvgs
Active Member
Hey Guys. I pulled the rally cluster out of my 70 Swinger 340 to change the fuel gage, I also installed new sockets and bulbs in the cluster.
I put the cluster back in the dash and the gages, wipers, heater, headlights all work. The green turn signal indicators on the cluster don`t light up when I use the signal lever, but the lamps do signal outside the car. (I have had some trouble with my turn signal switch causing brake light problems and have to replace it) Anyone believe the signal switch could be causing this issue on the dash? Thanks.
