I will soon start assembling my 71 360 and I need a harmonic balancer. Is there any difference in the La series 360 harmonic balancer? I looked on eBay and see that some OE styles state 1978 and later La years.
I'm sure the balancer you need to be correct, has got the big weight mounted on the front of the balancer. On the face of the balancer, it should be casted in there, should say ( for 360 cast crank motor). Hope this helps. Either try Ebay or push the search tab on the top of home page and seach, 360 Balancer. Ive seen some on this site sometime's. Good Luck.
