[FOR SALE] 1971 Complete 340 engine
QuintinMotorCompany
Georgia Vermont
Rating - 95.8%
23   1   0
1971 340 .. Very Complete including Aluminum Torker intake, thermoquad carb, M/T valve covers, and more!
Last ran in 1993.. needs rebuild!
Crank Drilled for 4 speed
Needs Rebuild!!
Nice starting point!
$1,100 OBO + freight or local pickup from 05454
Please post block numbers to cut down on all this conversation. PM sent to seller. Thanks, toolmanmike (moderator)
Pull the heads off and make sure its a good block.
Did it have antifreeze in it when you pulled it out?
Yes please do. Most of us are quite always from you. Buying would be easier if we knew more. I won't buy it till I see it and put my hands on it anyway...But a picture of a rusted and corroded engine don't help much...
Wow! what does the plate say? very hard to see. looks like rods .030, mains .010,
bore .060, cant make out the rest.
Yes,that's what it looks like too me too. Obviously it's been rebuilt before, but those are not good numbers...
Take it to .090 on the bore, see if you strike water. Unless you have the car and want to sleeve it, just heads and accessories.
