1971 dart Strut Rod bushing installation
fastr1
florida
I have read a ton of the posts here and thankfully so, however I am replacing the poly bushings for the early model fine thread rods that are incorrect for the car and not allowing max caster and also allowing the lower control arm to slip on the Proforged pivot kit I have, however I cannot find a correct picture of how the one piece rubber bushings are to install in the front crossmember, with the taper towards the bumper or towards the lower control arm, I'm suspecting it faces forward, but this is holding me up. Thanks,
This link may help and is how i'm doing this,
https://www.forabodiesonly.com/mopa...opar-p4529183-front-strut-bushing-pkg.385485/
Thanks,
